ardyne
#1 Posted : 16 years ago
ardyne
Roper wash machine RAX7244jQo agitates great and pumps water out.. will not spin. I washed some bathroom rugs the other day.. could there be lint or other binding the agitator? is that possiable. also what is the easiest way to get the agitator off. Thanks for the advise greatly appreciated ! Ardyne.. P.s. Washer could be over ten years old? is there a date stamp on it somewhere?
#2 Posted : 16 years ago
Lift the washer up from the front and check if there are white or black shavings on the floor. If there are some then the problem is a bad motor coupling. I do not see why you have to remove the agitator - it has nothing to do with spin.
Here are the break down diagrams for the Roper washer Model RAX7244JQ0
ksmckee
#3 Posted : 16 years ago
ksmckee
Hello Gene can you help me please my washer will fill it wont wash it makes a noise an it wont spin i had to shift the knob an hold the button down to drain it. do you know what is wrong an where the part is i dont know anything about them. thank you kris is there a place i can go to see a diagram model no is RAX4232KQ0
ksmckee
#4 Posted : 16 years ago
ksmckee
model no is 27A2170(3b)
#5 Posted : 16 years ago
