Karts03
#1 Posted : Monday, March 2, 2009 11:07:18 AM(UTC)
Karts03
Like everyone else on here with a electric dryer issue, mine doesn't heat either. I'm pretty handy, even being a woman, so I pulled the heating element to bring to the appliance parts guy to check it just in case. I had already replaced this unit about 1-1 1/2 yrs ago. He tested everything and it wasn't that. Even hooked it up to an outlet and it heated up. He gave me a new fuse to try. After getting to the old fuse, I installed the new one, put everything back together, and still no heat.
The dryer tumbles, no heat just cold air. I called the parts guy back to tell him that wasn't it either. He said something on the harness block probably needs to be replaced but I couldn't do that myself and to call someone. He maybe underestimating my abilities or he may be dead on.
I also tried flipping the 2 breaker switches to make sure they didn't trip and just didn't register. Still nothing...
Drags1998
#2 Posted : Monday, March 2, 2009 2:22:23 PM(UTC)
Drags1998
Check the thermostat at the TOP of the heater can!!! Make sure to ALWAYS unplug the unit before working on it!!!! The thermostat can be checked by unplugging the 2 wires from the thermostat and connecting them together, Taping them up carefully!!! and trying the dryer. If it works, replace the thermostat!!!:D
#3 Posted : Monday, March 2, 2009 3:43:19 PM(UTC)
Model GEQ9800PW2
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208541831.pdf
All devices along the heating circuit (bottom of diagram) must be closed for you to get heat. Also the motor's centrifugal switch must close but they are fairly reliable, check the other items first
It may be time for you to move up a notch i9n your DIYer skills
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
