Freezer keeps everything frozen but won't defrost, frig side won't get coolder than 50 degrees. I shut it off for 24 hrs. both sides worked fine for 48 hrs. then same thing again.
First you need to be sure you have a defrost problem. There is a picture here that shows what the evaporator coils will look like if there is a defrost problem. Refrigerator Defrost Problem Diagnostics [FONT='Times New Roman'] There are four things that will cause a defrost problem with these types of refrigerators and they are the defrost heater (most common), evaporator thermistor, defrost thermostat and the main board. This page will show how to diagnose this type of problem. [/FONT] [FONT='Times New Roman'] [/FONT] [FONT='Times New Roman'] Refrigerator Defrost Problem Diagnostics[/FONT]
