need help on what to check so it will drain
Here are your parts Model GSD3800G00CCNeed more info, can be many things What does it do? Does it try to drain re: motor running etc? Have you checked anything? Does the drain solenoid activate? Behind the kick plate on the motor/sump assembly. left hand side. |
THIS FORUM IS DEAD!!!!!!! |
