2 Pages<12
jttaylor
#11 Posted : Monday, February 13, 2012 9:08:51 AM(UTC)
jttaylor
The part should be delivered today. I was hoping to get it earlier for the weekend when I had time to replace it. Anyway, I'll put it in as soon as I can. I'll probably defrost manually again, then it might take a couple of weeks to know for sure if it's working right.
jttaylor
#12 Posted : Wednesday, February 22, 2012 5:47:59 AM(UTC)
jttaylor
I replaced the thermistor a few days ago. The old one did seem to be bad when I tested it, it showed about 1.7K ohms when it should have been about 16.3K. The others tested OK. I'll probably take a look at the coils in a few more days out of curiosity, but will likely need to wait a couple of weeks to know for sure if it's working correctly.
jttaylor
#13 Posted : Monday, March 19, 2012 5:35:17 AM(UTC)
jttaylor
The fridge seems to be working fine now. It's been over 4 weeks since replacing the thermistor and there haven't been any problems. Thanks for your help Gene.
#14 Posted : Monday, March 19, 2012 11:07:57 AM(UTC)
You are welcome. I'm glad it's up and running.
Thank you for the feedback.
lloyd329
#15 Posted : Sunday, March 25, 2012 12:51:33 PM(UTC)
lloyd329
Looking at the picture on the first page, it looks like my coils when they were froozen over. I completely defrosted them yesterday. Freezer and fridge are cooling properly now. While I am waiting to see if it freezes up again, I am going to order the thermister since it is so cheap. However, when I removed the back panel there was a green wire partially sticking out the top of the panel near the light bulb. It had a clip like metal thing on the end. Without taking the panel back off and taking a picture of it, does anybody know what it is for and if it needs to be attached to anything??
#16 Posted : Monday, March 26, 2012 10:23:28 AM(UTC)
Most likely this is the ground wire to connect the ground to the rear panel.
jttaylor
#17 Posted : Monday, March 26, 2012 11:45:47 AM(UTC)
jttaylor
Yeah, that should be the ground wire that just clips to the top of the panel.
2 Pages<12
