Just installed a new Washing machine and it leaks internally!! Rather than take it out and carry it down 2 flights of stairs I'd like to remove the casing and see what is leaking. Any ideas where to begin removing the casing....., Thanks in advance. Danny.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks Gene...., leak appears to be comoig from the outer tub.:mad: Having a hard time getting the casing back on (does it hook over or under the base)??
Duh!! found it....,(part 2) Thanks again Gene. Off we go down the stairs and back to Best Buy!!
