danbhoy67
#1 Posted : Tuesday, November 20, 2007 3:30:45 PM(UTC)
danbhoy67
Just installed a new Washing machine and it leaks internally!! Rather than take it out and carry it down 2 flights of stairs I'd like to remove the casing and see what is leaking. Any ideas where to begin removing the casing....., Thanks in advance. Danny.
#2 Posted : Tuesday, November 20, 2007 5:20:01 PM(UTC)
Here are the complete instructions how to remove the cabinet on the direct drive washer.
danbhoy67
#3 Posted : Tuesday, November 20, 2007 9:16:06 PM(UTC)
danbhoy67
Thanks Gene...., leak appears to be comoig from the outer tub.:mad:
Having a hard time getting the casing back on (does it hook over or under the base)??
danbhoy67
#4 Posted : Tuesday, November 20, 2007 9:20:50 PM(UTC)
danbhoy67
Duh!! found it....,(part 2) Thanks again Gene. Off we go down the stairs and back to Best Buy!!
