m/c
#1 Posted : 18 years ago
m/c
I just purchased a new water inlet valve, it is a three solenoid valve and the new part appears to have quick connect type water line fittings ( or something) on 3 of the outlets and 2 of the outlets use the threaded type water line connections on the new part ,, my old inlet valve uses threaded connections on all the water lines on the valve, the valve looks the same except for how the water lines connect to the new valve , do I have a wrong part ? how do I connect the lines ? or should I send it back for a return , it's useless the way it is out of the box since my frige uses all threaded type water line connections ..... any help or info would be much appreciated .................. thanks
ApplianceJunk
#2 Posted : 18 years ago
ApplianceJunk
There should have been some instruction in the box.
Does your new valve have fittings like the one in this video?
Video: Connect and disconnect a push-in ice maker water fill valve plastic line
If so then you cut your old plastic nut ends off and slip the line into the new valve.
Hope that helps,
m/c
#3 Posted : 18 years ago
m/c
Hope that helps,
Thanks appliancejunk for the reply and the video link and yep the inlet valves have switched to quick connect fittings,the one that was sent was missing some of the quick connect inserts, Adam from this site is sending another unit (thanks Adam) and I'll see how it goes ...... take care
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 11 months ago
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
Water inlet valves burning out (Dishwasher Repair)
by Tydinelle about a year ago
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest about a year ago
Whirlpool Water Inlet Valve Repair for Leak (Refrigerator & Freezer Repair)
by ForumUser1 about a year ago
Water Inlet Valve WR57X10033 / AP3189335 for General Electric DTL18ICSRRBS (Refrigerator & Freezer Repair)
by breckrider 2 years ago
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 4 years ago
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 4 years ago
Leaky new water inlet valve on whirlpool gold refrigerator (Refrigerator & Freezer Repair)
Water Inlet Valve for Whirlpool WRF560SEYW05 (Refrigerator & Freezer Repair)
by nycgene 5 years ago
Noise after water inlet valve replacement (Refrigerator & Freezer Repair)
by Kristsivia 5 years ago
GE washer replace WH13X10057 water inlet valve (Washer Repair)
by Cmath 8 years ago
Water inlet valve (Washer Repair)
by dcbradt 8 years ago
Water inlet valve leaking (Washer Repair)
by Jimh64 9 years ago
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 9 years ago
