9 Pages«<34567>»
#41 Posted : Friday, February 3, 2012 3:46:29 PM(UTC)
Hi Todd,
It is possible that the problem is a bad evaporator (freezer) fan motor. If it's bad then it will damage the main control board. I really recommend to order the new fan motor and replace it together with the new main control board. Otherwise the third control board will get damaged again.
- The evaporator fan motor Part number: AP3875639
ws6s
#42 Posted : Friday, February 3, 2012 4:02:53 PM(UTC)
ws6s
ok gene ordered,
hopefully the fridge will hold on till it arrives.is the fan an easy install ?
thanks todd
#43 Posted : Friday, February 3, 2012 4:35:07 PM(UTC)
You are welcome Todd.
The instructions are attached to the reply.
File Attachment(s):
Freezer evaporator fan - 1.doc (1,437kb) downloaded 9 time(s).
Freezer evaporator fan - 2.doc (976kb) downloaded 6 time(s).
ws6s
#44 Posted : Friday, February 3, 2012 7:14:28 PM(UTC)
ws6s
hey gene i ordered the fan without the thermistor,is that the right one for my unit,
also thanks.
#45 Posted : Saturday, February 4, 2012 4:09:35 PM(UTC)
This part number comes up by the model number you posted.
ws6s
#46 Posted : Tuesday, February 7, 2012 6:07:42 PM(UTC)
ws6s
gene got the part and just tore down the freezer and sure enough mine is the one with the thermistor,it figures.guess i will order the thermistor style fan now.:mad:
Todd
#47 Posted : Tuesday, February 7, 2012 6:20:32 PM(UTC)
Todd,
You can splice in the new motor wires into the old harness.
ws6s
#48 Posted : Tuesday, February 7, 2012 6:23:44 PM(UTC)
ws6s
are you sure i should do that gene\
ws6s
#49 Posted : Tuesday, February 7, 2012 6:34:13 PM(UTC)
ws6s
ok canceling order and splicing
#50 Posted : Tuesday, February 7, 2012 6:36:03 PM(UTC)
You can but APP would not take it back in case of any alteration.
Guest (13)
9 Pages«<34567>»
