Jim E
#1 Posted : Thursday, February 26, 2009 4:13:32 PM(UTC)
Jim E
Hello,
My first time posting, I have roper wall oven and the ignitor will not lite.
I have replaced the ignitor and still have the same problem, It will not lite. The biggest problem is parts are hard to find for a 27 year old wall oven. I was wondering if it could be the control valve?? I am trying to fix it because it is still in good shape. Any and all info or ideas would be greatly appreciated.
Thanks in Advance,
Jim
TechnicianBrian
#2 Posted : Thursday, February 26, 2009 4:23:21 PM(UTC)
TechnicianBrian
You need to take a voltage reading across the igniter and see if you are getting 120vac when a cycle is started. If you don't have voltage, then it's time to look at the control/thermostat as a possible problem. There is an off chance the valve could be the problem but you need to verify voltage first, and then move on to the rest of the circuit.
oven will not lite (Oven Repair (including Ranges and Cooktops))
Belarus Rick2112 11/18/2013 6:49:53 PM(UTC)
Thermador PGR364GL Oven will not lite (Oven Repair (including Ranges and Cooktops))
by PaulKru 5/15/2012 9:34:55 AM(UTC)
by ralp 8/17/2009 7:22:21 AM(UTC)
by schautz86 2/10/2008 11:03:36 AM(UTC)
