erocki
#1 Posted : Thursday, February 26, 2009 2:48:33 PM(UTC)
erocki
This has only lasted less than 3 years. I am a little annoyed but nevertheless need you help to rectify the problem.
Leaking near the center seal...looks like from the outside of the nut so I am guessing the tough job.
Let me know if you see anything different...
What is the best resource for step by step instructions to repair this...? I cannot afford a new washing machine.
Thanks in forward...
E
erocki attached the following image(s):
#2 Posted : Friday, February 27, 2009 4:04:04 AM(UTC)
Model LAV3600AWW
Here is a service manual
Model LAV3600AWW
Only thing I can suggest is dry it off good, perhaps use a hair dryer on it.
Also make sure the tub is dry.
Run a load and see if perhaps the water is leaking somewhere else , running down the tub till it drips off the center seal.
Cannot see in the pictures.
Above is just to double check. Pulling it apart is going to be a pain so it is best to be absolutely sure of the leak location.
