sanddj
#1 Posted : Thursday, February 26, 2009 12:06:35 PM(UTC)
sanddj
We have a kitchen aid dishwasher that is not cleaning the dishes. I have replaced the upper arm asm because it was bad. I also replaced the nylon radial bearing, bearing ring and the restrainer nut. when we run thru a normal wash cycle and open the door to stop it appears that neither the top arm or lower arm are rotating. It fills with water and will pump it out.
[FONT='Times New Roman']So can someone tell me what wrong[/FONT]
sanddj
#2 Posted : Thursday, February 26, 2009 12:10:12 PM(UTC)
sanddj
#3 Posted : Friday, February 27, 2009 11:27:34 AM(UTC)
Can you hear the pump running during the wash cycle?
sanddj
#4 Posted : Saturday, February 28, 2009 5:41:10 AM(UTC)
sanddj
How to you tell the differents between the motor and the pump.
When it run it sounds like it goes thru the nomal cycles. It fills and runs and will pump the water out, but it appears that the arm don't rotate. If I open the door during a cycle and look at position of arm and then close the door and let it run again and then open door again the arms have not moved. There is water coming out of the lower arm, but not enough to make it rotate.
#5 Posted : Saturday, February 28, 2009 3:52:48 PM(UTC)
Make sure the water level is above the heater.
Remove the pump cover and check all impellers and balls.
Here are the break down diagrams and the parts list for the Kitchen Aid dishwasher Model KUDS24SEAL5
sanddj
#6 Posted : Sunday, March 1, 2009 5:40:30 AM(UTC)
sanddj
Make sure th water level is above the heater.
Gene I got it fixed on Saturday. The screws othat hold the pump cover were all loose and 3 had come out which blew the gasket out. I was able to replace the gasket and screws and now it seem to work fine.
Thank you for your replys
David
#7 Posted : Monday, March 2, 2009 11:43:31 AM(UTC)
You are welcome. I'm glad you were able to fix it.
Guest (4)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
