I bought a WB27T10190 from APP. What came was a WB27T10174 control. The only instruction page told me how to wire the WB18T10124 harness adaptor. There are no instructions for how to wire the WB18T10123 3 terminal jumper, even though it's obvious that the plastic connector end goes on relay 101. There is also an addition M/F jumper in the kit. One of the relays on the new board would take a wire at the "COM" terminal.
That would still leave 3 wires "unhooked" in my stove: the green ground wire, a black 3 jumper wire that went to "L1" and "C" and another "L1" on the old board, and a black wire w/white stripe that used to go to "NO" on the old board.
It's like I need another page of instructions, but APP said this is all that comes with it. Anyone have any greater wisdom before I reluctantly ship it back?
I also bought the WB27T10174 control unit and the instructions are completely worthless. I've looked all over the Internet for a solution and a lot of people have been complaining about this "retrofit" because the instructions are incomplete and VERY difficult to read. The photos are a joke because they have been copied so many times you can't see anything. The manufacturer or the parts distributors need to step up with a solution before someone gets hurt or burns their house down.
Is ANYONE out there listening?
