Greg Z
#1 Posted : Friday, January 27, 2012 5:22:22 PM(UTC)
Greg Z
Washer is sending an f51 error with 9 minutes left in the cycle. It's not spinning completely. Any suggestions on how to determine if it is the sensor or the control board?
sidfink43
#2 Posted : Sunday, January 29, 2012 7:45:57 AM(UTC)
sidfink43
The tech notes inside the washer will tell you how to conduct a test to better locate the problem. Test #3 is a fairly long and involved process, but it should help you determine what is at fault.
