otison
#1 Posted : Saturday, January 28, 2012 10:26:29 AM(UTC)
otison
My freezer quit working, fridge was fine. Ice was building up in freezer so I defrosted with hair dryer, vacuumed the back out. Still won't freeze and fridge is getting warm, I replaced the defrost timer; freezer is colder but still not freezing, fridge not as cold as it should be. Please Help Me
#2 Posted : Sunday, January 29, 2012 3:26:36 AM(UTC)
Is the compressor warm and vibrating and both freezer and condenser fans running?
otison
#3 Posted : Sunday, January 29, 2012 9:59:39 AM(UTC)
otison
Yes to all three.
#4 Posted : Sunday, January 29, 2012 11:11:30 AM(UTC)
If the condenser is also warm, you have a bad compressor and or refrigerant leak. Amprobe and gauges would confirm. If you pull the freezer back panel and see partial frost, that would confirm it. It's also possible you have a restriction in the cap tube or a oil filled dryer. An amprobe would confirm, but rather rare.
otison
#5 Posted : Monday, January 30, 2012 8:42:56 AM(UTC)
otison
I checked heater with an ohm meter and it is not working. Could another problem have caused this? Troubleshooting says to check thermostat also but would I have to cut wire to do that? (and where is condenser?)
