ranmar
#1 Posted : Sunday, February 22, 2009 11:11:33 AM(UTC)
ranmar
Have error codes E2 F1. Turn off breaker and it will work for a while, then codes again. How do I check oven sensor and control board? Thanks
kayakcrzy
#2 Posted : Monday, February 23, 2009 4:47:20 AM(UTC)
kayakcrzy
Ohm out the sensor. It should read 1100 ohms if it is good. If so replace the board. Tom
ranmar
#3 Posted : Wednesday, February 25, 2009 5:21:54 AM(UTC)
ranmar
is this the 6" probe in oven ? and how do I test it will the ohm meter?
kayakcrzy
#4 Posted : Wednesday, February 25, 2009 5:59:19 AM(UTC)
kayakcrzy
Yes it is, and you have to take the back off the oven, and unplug the molex plug, and then put your meter on ohms, and put the meter leads on each of the pins and get a reading. Tom ApplianceEducator.com
