AsphaltPays
#1 Posted : Wednesday, January 18, 2012 12:44:41 PM(UTC)
AsphaltPays
My refrigerator is stuck at 58 degrees. We just replaced the main board as the temperature contol settings were not lighting up and it would not cool at all. The compressor is kicking on and off and it is set at the factory settings of 0 and 38. Any ideas of what the problem could be now?
#2 Posted : Thursday, January 19, 2012 3:21:20 AM(UTC)
Remove the motherboard cover and locate the 3 pin power connector. Remove the connector and put a jumper wire between the connector mating pins as labled on the motherboard line and comp. Plug in refrigerator. If the compressor still kicks out, you might have a bad start device, rather rare for GE, but possible.
AsphaltPays
#3 Posted : Thursday, January 19, 2012 4:20:58 PM(UTC)
AsphaltPays
Thanks for the help compressor is shot...story of my life
#4 Posted : Friday, January 20, 2012 1:30:27 AM(UTC)
How do you know the compressor is bad?
Maytag fridge and freezer not cooling properly (Refrigerator & Freezer Repair)
by elliecats 12/27/2013 9:07:11 AM(UTC)
Fridge and Freezer not Cooling properly - GE PTC22SBMARBS (Refrigerator & Freezer Repair)
by DaHadster 5/16/2012 10:19:30 AM(UTC)
