tejyam@hotmail.com
#1 Posted : Tuesday, January 17, 2012 1:29:54 PM(UTC)
tejyam@hotmail.com
After using the self-clean cylcle, both lower and upper ovens won't heat up. The digital panel for the upper oven on comes on if I turn the dial on the lower oven to warm or higher.
Wondering what parts need to be replaced?
Thank you in advance for the help.
#2 Posted : Tuesday, January 17, 2012 4:13:46 PM(UTC)
Open the control panel and look for the Tech sheet inside. Post it if you can.
tejyam@hotmail.com
#3 Posted : Tuesday, January 17, 2012 6:55:15 PM(UTC)
tejyam@hotmail.com
Gene - Attached is the Tech sheet. Thank you for your assistance.
File Attachment(s):
GE Tech Sheet.pdf (1,693kb) downloaded 15 time(s).
#4 Posted : Wednesday, January 18, 2012 3:19:08 PM(UTC)
Looks like the "L1" 120 VAC leg (black wire) is missing. Try to reset the circuit breakers for the oven. If it would not help, check the voltage at the oven terminal block.
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 2/6/2019 11:56:18 AM(UTC)
