After using the self-clean cylcle, both lower and upper ovens won't heat up. The digital panel for the upper oven on comes on if I turn the dial on the lower oven to warm or higher.
Wondering what parts need to be replaced?
Thank you in advance for the help.
Open the control panel and look for the Tech sheet inside. Post it if you can.
Originally Posted by: Gene  Open the control panel and look for the Tech sheet inside. Post it if you can.
Gene. Gene - Attached is the Tech sheet. Thank you for your assistance.
Looks like the "L1" 120 VAC leg (black wire) is missing. Try to reset the circuit breakers for the oven. If it would not help, check the voltage at the oven terminal block.
