villano
#1 Posted : Wednesday, January 18, 2012 12:24:46 PM(UTC)
villano
Micro is not heating Fuse is good and touch pad executes commands. I tested the micro switches- all appear to be working. I tested the capacitor and it reads 1uF. Not sure if the diode affects operation of unit. I cannot get continuity accross it in either direction nor do I get a reading using a diode tester.
villano
#2 Posted : Wednesday, January 18, 2012 12:27:06 PM(UTC)
villano
mmmmmmmmmm
villano
#3 Posted : Wednesday, January 18, 2012 12:30:51 PM(UTC)
villano
:confused:
Amana microwave will not heat (Microwave Repair)
by ckiley 2/1/2013 11:51:23 AM(UTC)
Microwave will not heat (Microwave Repair)
by scottdugan 7/26/2012 7:29:30 AM(UTC)
by macguy44 12/31/2011 7:10:24 PM(UTC)
by vknipp 1/29/2011 9:42:28 AM(UTC)
by Cleatus 12/20/2010 4:40:14 PM(UTC)
Microwave will not heat anything (Microwave Repair)
by Stevew1987 1/2/2010 6:44:11 AM(UTC)
over the range Microwave will not heat (Microwave Repair)
by pdeclerck 12/27/2009 4:07:14 PM(UTC)
PLEASE HELP! Microwave will not heat (Microwave Repair)
by tratra 12/2/2009 8:28:30 PM(UTC)
Microwave Will not heat (Microwave Repair)
by Walt Lamb 4/2/2009 10:29:06 AM(UTC)
by Lou C 3/25/2009 1:57:18 PM(UTC)
by jrt1000 1/27/2009 7:34:52 PM(UTC)
Microwave Will Not Heat (Microwave Repair)
by ocstanley 12/28/2008 7:19:44 AM(UTC)
Microwave will not heat (all else is functional) (Microwave Repair)
by FLAD 12/15/2008 11:57:20 AM(UTC)
Microwave will not heat (all else is functional) (Washer Repair)
by FLAD 12/15/2008 10:38:17 AM(UTC)
Microwave will not heat and makes slight noise (Microwave Repair)
by vsmith 11/28/2008 4:09:36 PM(UTC)
