Terry C
#1 Posted : Monday, November 19, 2007 8:49:14 AM(UTC)
Terry C
Hi, I have a built in GE electric doubble oven, the control module(top oven) is frozen with what looks like all 8’s across the LED screen. I have disassembled it and I “think” I can narrow the problem down to either the control module or the control panel assembly. Is there an easy way to test out either one, or am I looking at a crap shoot here… Model #JKP27WOW1WW
Thanks for any help you can give me!
Terry
#2 Posted : Monday, November 19, 2007 8:25:11 PM(UTC)
If the power to the oven was off for a while, the first thing I would recommend is to turn the power on now and see if ti works.
Terry C
#3 Posted : Tuesday, November 20, 2007 6:17:51 AM(UTC)
Terry C
Thanks Gene, but I've done that a couple of times with the same results, right now I'm leaning twards the control "touch" panel assembly since it gets the most abuse. But without any type of code I'm just not sure...
#4 Posted : Tuesday, November 20, 2007 8:10:42 AM(UTC)
With the power to the oven off, open the control panel and remove the key pad ribbon from the slot in the control board.
Using an eraser, clean the end of the ribbon and plug it back.
Post the results.
Terry C
#5 Posted : Tuesday, November 20, 2007 11:52:31 AM(UTC)
Terry C
Thanks for getting back Gene,
Cleaned it up same scenario, everything’s lit up looks like all 8’s
#6 Posted : Tuesday, November 20, 2007 12:17:14 PM(UTC)
In such situation is very hard to say if the problem is a bad control board or a bad key pad.
I would start with the control board (ERC) because after the power up, 8s on the display should be switched to a blinking 12:00 by itself.
- The part number for the Control board AP3155966
- The part number for the white control panel AP2029545
- The part number for the black control panel AP2029544
Terry C
#7 Posted : Tuesday, November 20, 2007 12:39:47 PM(UTC)
Terry C
Thanks for your help Gene, I'll give the parts a try.
Terry
#8 Posted : Tuesday, November 20, 2007 12:48:50 PM(UTC)
Keep me updated, please.
Terry C
#9 Posted : Wednesday, November 21, 2007 7:15:56 AM(UTC)
Terry C
Thanks for your help Gene!
There will be Turkey tomorrow! Control board! Back in business...
Terry
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
GE Electric Oven - Won't stay on (Oven Repair (including Ranges and Cooktops))
by tstwingirls@yahoo.com 2/23/2022 3:51:15 PM(UTC)
GE Electric Oven Won't Heat After Storm (Oven Repair (including Ranges and Cooktops))
by ccar45 11/22/2013 8:29:38 AM(UTC)
Ge electric oven wrong temp (Oven Repair (including Ranges and Cooktops))
by mmzullo 12/2/2012 10:42:56 AM(UTC)
GE electric oven issue (Oven Repair (including Ranges and Cooktops))
by BobChurch 8/26/2009 10:34:19 AM(UTC)
GE Electric Oven Broiler not working (Oven Repair (including Ranges and Cooktops))
by jmltoyo 11/23/2008 6:16:57 AM(UTC)
GE electric oven (Oven Repair (including Ranges and Cooktops))
by skiplowflyin 6/5/2008 6:01:42 AM(UTC)
