lmcd
#1 Posted : Sunday, January 15, 2012 10:28:19 AM(UTC)
lmcd
:mad: We decided to clean our oven after the Holidays.
So on our Whirlpool Gold oven we hit the self cleaning button and I dont know if the oven died during cleaning or after the cleaning, but there is not LED display, nothing.
Suggestions
ramblinche81
#2 Posted : Sunday, January 15, 2012 5:46:33 PM(UTC)
ramblinche81
Suggestions
Could be thermal fuse which protects from overheating.
Easy to test with Ohm multi meter. Turn off at breaker panel before attempting.
If thermal fuse is good, your control board is likely baked.
#3 Posted : Monday, January 16, 2012 3:29:35 AM(UTC)
Here is a link to a similar recent post.
Yours should be a close match as it is also a GBD307.
http://forum.appliancepartspros.../403893-double-oven.html
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line and the breaker does not trip.
