Lights inside come on when I open the door. display doesn't work and both ovens do not come on. Is it the control panel gone out or just a fuse?
Originally Posted by: ljreed7 Lights inside come on when I open the door. display doesn't work and both ovens do not come on. Is it the control panel gone out or just a fuse? Without a wiring diagram available it could be one of three things. Thermal fuse (have you run self clean lately) could have failed. Easy to check with Ohm multi meter...DISCONNECT POWER / BREAKER before you attempt. If thermal fuse is still good, then it could be one phase of power supply coming in. Should have 220-240v....that would mean your breaker failed more than likely. The one phase working is powering your lights. The phase that failed feeds the board...hard to say without a diagram. And lastly, if both above are good, then your control is deep fried.
THIS FORUM IS DEAD!!!!!!! |
