gamtnman
#1 Posted : Saturday, January 14, 2012 8:30:57 AM(UTC)
gamtnman
My GE side by side freezer runs constantly. The water dispenser does not dispense water, so I assume it is frozen. The temp in the freezer is O degrees F. The refrigerator side is 40 degrees F. Should I replace the control board? Thanks.:)
#2 Posted : Saturday, January 14, 2012 8:38:53 AM(UTC)
Remove the back freezer panel and describe the frost pattern, defrost if necessary and post freezer temperature.
gamtnman
#3 Posted : Saturday, January 14, 2012 9:19:45 AM(UTC)
gamtnman
I that panel accessed from the inside or the outside?
#4 Posted : Saturday, January 14, 2012 10:37:18 AM(UTC)
From the inside, remove all the shelves.
gamtnman
#5 Posted : Saturday, January 14, 2012 1:17:26 PM(UTC)
gamtnman
Very heavily iced. Defrosted it. Temp back at 0 degrees.
#6 Posted : Sunday, January 15, 2012 12:46:38 AM(UTC)
Remove the motherboard cover, remove the 3 pin power connector and place a wire jumper between the connector pins that mate with the board pins labeled line and def. Plug in fridg, if you get defrost replace the motherboard AP4436216, if not replace the defrost heater and defrost thermostat clipped to the top of the evaporator.
gamtnman
#7 Posted : Sunday, January 15, 2012 5:18:37 AM(UTC)
gamtnman
Thanks. Stupid question I guess, but how will I know if I have defrost? Remove the inside cover and watch?:o
#8 Posted : Sunday, January 15, 2012 5:43:11 AM(UTC)
Yes that will work. Make sure the freezer is cold and compressor running when you do this and of course pull the plug.
gamtnman
#9 Posted : Sunday, January 15, 2012 6:13:38 AM(UTC)
gamtnman
Thanks much. I will do that and what what happens.
