jmontgom
#1 Posted : Thursday, January 12, 2012 4:47:54 PM(UTC)
jmontgom
My Washer is leaking water. I took off the back panel and did not see anything obvious. The washer fills up fine and then shortly after water starts trickling out of the front right corner. Any help is greatly appreciated. The last time I had a problem with this washer you guys helped me put a new control panel and it went great. Now I hope I can fix this problem.
sidfink43
#2 Posted : Saturday, January 14, 2012 5:06:21 PM(UTC)
sidfink43
Run it with the front service panel off and I think you will see that the leak is coming from the pump or hoses.
Frigidaire Leaking water to floor (help!!) (Refrigerator & Freezer Repair)
by JB235161 11/13/2015 12:16:25 PM(UTC)
Frigidaire leaking water inside when not on (Dishwasher Repair)
by Kim Smith 11/18/2010 3:29:58 PM(UTC)
Frigidaire leaking water from water inlet valve (Refrigerator & Freezer Repair)
by Swordfish5150 7/27/2010 8:33:52 AM(UTC)
by Swordfish5150 7/26/2010 1:14:15 PM(UTC)
Frigidaire leaking water (Refrigerator & Freezer Repair)
by aenonnenmacher 7/16/2008 4:33:07 AM(UTC)
