Captron66
#1 Posted : Monday, February 23, 2009 7:26:06 PM(UTC)
Captron66
The dryer had been running cool for some time. Model LTE6234AW1. It took at least 2 cycles to dry.Vents are clear.had exhaust off and it is clean. I replaced the high limit thermostat to try to fix the problem. Ran it with the new hi limit and the over temp fuse on heater chassis blew. Argh. The dryer is 13 or 14 yrs old. The heater coil resistance falls within spec ( 11.7 ohms) . I did notice prior to blowing the fuse that the air out the side of the house is not as strong as when the hose is disconnected at the back of dryer. Again , I am positive of no obstructions with vent line. The run is about 6' long. I have a meter and know how to use it. Your help is much appreciated.
#2 Posted : Tuesday, February 24, 2009 2:14:12 AM(UTC)
Model LTE6234AW1
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%203398986.pdf
You will see that they show the High Limit and a Thermal Cutoff as a set.
This usually indicates that it is a good idea to replace both.
The high limit should not come into play if everything is working OK.
It is a safety device
The unit should run on the cycling thermostat.
Does sound like an air flow problem, could be
1. Coated lint filter. If you use fabric softener it can coat the filter screen greatly reducing air flow. Clean it with soap and water.
2. The blower wheel may be stripped so that it is slipping on the motor shaft
3. The blower wheel is clogged up with lint
4. One of the seals on the blower to lint filter is shot
5. Drum seals shot
You are sucking the air through the dryer and then pushing it out the vent so anything that allows air leaks will reduce the air flowing through the heater assembly. This will reduce the temp in the drum causing longer dry times. Also may explain why the thermal fuse on the heater assy blew.
Captron66
#3 Posted : Tuesday, February 24, 2009 5:55:35 AM(UTC)
Captron66
Checked blower fan ,not slipping. Gaskets between blower and lint screen look good.lint screen not clogged. How hard is it to change the felts on the drum?
#4 Posted : Tuesday, February 24, 2009 7:00:06 AM(UTC)
They are not difficult to change Take the old ones off, clean up the surface, glue on the new ones, let the glue set and reinstall. You have to pull the drum out to do it so unless you know they are shot I would not.
Sort of stumped here, my gut still says it is an air flow problem but everything looks OK.
Only other thing I an think of is that the cycling thermostat has gone crazy and is not opening/closing consistently at the set points. The norm for these is to fail by either welding the contacts closed or blowing the contacts but it might be the cause.
Unit was running cool, you replaced the high limit thermostat which should have no effect at all. then the thermal fuse blows. Something has changed!!!
Remove the wires from the heating element and check them to the case.
Should be an open. This will check for a grounded element. This is a long shot.
Hopefully others will jump in with more possible causes.
Captron66
#5 Posted : Tuesday, February 24, 2009 1:17:16 PM(UTC)
Captron66
Changed hi limit and and thermal cut off as a set. It's working ok so far.
Kenmore gas dryer not hot enough (Dryer Repair)
by Brixey 1/22/2013 2:03:15 PM(UTC)
Estate Whirlpool gas dryer not hot enough (Dryer Repair)
by Remi32 1/10/2011 6:16:23 PM(UTC)
Gas Dryer Not Hot Enought (Dryer Repair)
by Jimmyd 4/7/2008 12:46:39 PM(UTC)
