vsimpson@ledic
#1 Posted : Wednesday, January 11, 2012 10:33:11 AM(UTC)
vsimpson@ledic
I have a Hotpoint electric oven that is getting extremely hot. I have replaced the thermostat and problem remains. Also the oven indicator light now will not go off. Any help will be appreciated.
#2 Posted : Wednesday, January 11, 2012 3:04:44 PM(UTC)
The model number you posted does not come up. Verify and repost it please.
vsimpson@ledic
#3 Posted : Thursday, January 12, 2012 6:20:53 AM(UTC)
vsimpson@ledic
Sorry, the correct model number is RB526DP1WW
#4 Posted : Friday, January 13, 2012 12:59:57 PM(UTC)
How did you connect the new thermostat?
What did you mean when you said it's getting extremely hot? Did you measure the temperature inside the oven?
vsimpson@ledic
#5 Posted : Thursday, January 19, 2012 6:52:57 AM(UTC)
vsimpson@ledic
Gene, I used another stove as a guide as to how to reconnect the thermostat. Before that I placed a thermometer inside the oven to get an accurate reading. With the oven set on 250 I viewed the thermometer and it was reading around 500 degrees. I've replaced the element inside, as well as the thermostat switch with no change. I do not have a troubleshooting guide or schematic to help with this problem so thanks for whatever help you can provide.
