vicki beauchamp
#1 Posted : Sunday, January 8, 2012 10:41:40 AM(UTC)
vicki beauchamp
My oven worked Christmas Eve and not on Christmas Day!!!
The Time, convection fan, and controls all work, but no warmth from any settings. The digital readout says Pre-Bake 170 and nothing gets warm. Do I need a new control panel or relay panel or both?:eek:
#2 Posted : Monday, January 9, 2012 4:18:34 AM(UTC)
Replacement parts for AOCS3040SS models | AppliancePartsPros.com
I am assuming that everything looks normal just no heat.
Try the following first. The control, fan, etc. use half the line (120 volts) but the elements require the full 240 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Many units have a thermal cut-off (fuse) in line with the elements.
The parts do show a limit kit (Item 38 in Section 2) but I do not have a wiring diagram so am not sure what this part is doing.
If it has a fuse often they blow after a long self clean cycle.
Other causes are a bad oven sensor or a sticking relay on the control board or sometimes they just blow for no apparent reason.
I will do some more searching to see if I can find a wiring diagram.
#3 Posted : Monday, January 9, 2012 5:46:49 AM(UTC)
Here is a manual
16021875 Maytag Amana Electric Wall Oven Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
I am not sure what info is in the manual as it will not let me download it.
Hopefully you will have better luck.
