plasmagames
#1 Posted : Saturday, February 21, 2009 7:15:18 PM(UTC)
plasmagames
The glass top on our range is cracked. There's a hole the size of the big element.
Does anyone know where to get the parts and how to install them.
TechnicianBrian
#2 Posted : Saturday, February 21, 2009 7:21:55 PM(UTC)
TechnicianBrian
The cook tops are usually easy enough to replace once the screws are removed along the front edge. The top will hinge up along the back then the elements can be moved from the old top to the new top. I can locate the part number for your range if you like, but the model number you provided does not show in Frigidaire's library. Double check the number and get all the letters at the end to ensure you get the correct part.
plasmagames
#3 Posted : Saturday, February 21, 2009 7:31:34 PM(UTC)
plasmagames
the exact model number of of the range is PFEF373CS2, it's white and has a 30" Width Glass Top
TechnicianBrian
#4 Posted : Saturday, February 21, 2009 7:46:48 PM(UTC)
TechnicianBrian
The part number I found from Frigidaire is 318154603 but a quick search of my normal local and Internet part suppliers either show it no longer available, part number doesn't exist, or requires special attention, ie., we don't know. So some looking around yourself and see what you can find. If you look for a used appliance store in your town, they are a good resource of some older parts that are still in good shape. Hope this helps.
plasmagames
#5 Posted : Saturday, February 21, 2009 8:04:43 PM(UTC)
plasmagames
would i be able to use a glass top from a similar model that is 30"?
TechnicianBrian
#6 Posted : Saturday, February 21, 2009 8:35:14 PM(UTC)
TechnicianBrian
I checked a few other models that had similar element layouts and their part numbers came back the same as yours. That is why I suggested the used route because you need the same element pattern and element mounts to ensure it will fit correctly. If you can see that top and make a comparison, you may find something similar that will work for you. The current production 30" ranges similar to yours have a top (AP3960212) that use a different method of mounting the elements along with how they attach to the range chassis. I don't know how different it would look when setting on the range, but you would need to purchase the new mounting brackets to mount the elements. It may work, but you may want to look at one in person before placing an order.
plasmagames
#7 Posted : Sunday, February 22, 2009 5:50:54 AM(UTC)
plasmagames
That Top might not work because the elements on ours is different in the front left we have a bid element, unless that picture is up side down or tooken up side down, then it's fine
plasmagames
#8 Posted : Sunday, February 22, 2009 5:54:28 AM(UTC)
plasmagames
ya that one won't work
i checked the page for that model of range and the elements are in a different place or can we move our elements
plasmagames
#9 Posted : Sunday, February 22, 2009 6:08:28 AM(UTC)
plasmagames
i looked at it again and that range top would work
TechnicianBrian
#10 Posted : Sunday, February 22, 2009 6:12:40 AM(UTC)
TechnicianBrian
Elements can be adjusted, but it depends on the if you have room in the wire harness, They can be moved to another position, but you may also need to move the infinite switch that provides the electrical current. The greater problem you may have is your range has an oven vent the is on the right rear, while all the newer (say last 6 years) have the vent on the left running under the control panel. So I don't see any of the new cook tops working for you.
Guest (4)
cracked glass top gas (Oven Repair (including Ranges and Cooktops))
by elricw 2/20/2011 5:07:22 PM(UTC)
Cracked glass top stive (Oven Repair (including Ranges and Cooktops))
by JShockley 12/11/2010 10:41:48 AM(UTC)
Cracked Glass in Door of older Magic Chef Wall Oven (Oven Repair (including Ranges and Cooktops))
by mark2741 2/10/2010 7:01:47 AM(UTC)
Cracked glass (Oven Repair (including Ranges and Cooktops))
by here4real 12/14/2009 1:08:55 PM(UTC)
Cracked Glass Top (Oven Repair (including Ranges and Cooktops))
by bnmmunson 10/9/2009 9:52:59 AM(UTC)
by TheresaZ 7/2/2009 3:43:38 PM(UTC)
cracked glass cook top (Oven Repair (including Ranges and Cooktops))
by zell66 7/1/2009 3:52:54 PM(UTC)
Replacing Cracked Glass on Cooktop (Oven Repair (including Ranges and Cooktops))
by jusacruiser 3/30/2009 12:02:52 PM(UTC)
Need to replace cracked glass cooktop (Oven Repair (including Ranges and Cooktops))
by csbunnell 3/2/2009 9:42:02 AM(UTC)
Cracked glass stovetop (Oven Repair (including Ranges and Cooktops))
by paulk1 11/1/2008 6:15:02 PM(UTC)
Cracked Glass Cooktop (Oven Repair (including Ranges and Cooktops))
by ROBERT PAGE 6/16/2008 3:43:33 AM(UTC)
Cracked glass on oven (Oven Repair (including Ranges and Cooktops))
by wessell 2/3/2008 8:42:44 PM(UTC)
Frigidaire cracked glass cooktop (Oven Repair (including Ranges and Cooktops))
by mchome76 1/1/2008 2:06:37 PM(UTC)
