bobmullen364
#1 Posted : Friday, January 6, 2012 3:28:13 PM(UTC)
bobmullen364
The bottom oven won't heat, broiler works ok. Top oven works fine. Checked continuity on the bottom element and it measures open. Checked ohms on the temp. probe and it reads zero. What are the chances both parts could be bad?:confused:
ramblinche81
#2 Posted : Friday, January 6, 2012 5:49:16 PM(UTC)
ramblinche81
You can always move the upper bake element down to the lower oven, and if lower unit now works properly, then probe is good.
It is possible the probe picked up a short when being removed, but not likely.
Good luck
bobmullen364
#3 Posted : Saturday, January 7, 2012 4:58:41 AM(UTC)
bobmullen364
Good luck
I looked into that but the elements are not even close to being the same and don't connect at the same place.
ApplianceJunk
#4 Posted : Saturday, January 7, 2012 5:05:44 AM(UTC)
ApplianceJunk
I think if your temp probe was bad the oven would display a fault code.
Here is the service manual for the Maytag Gemini.
http://appliancejunk.com...wnloads;sa=view;down=390
bobmullen364
#5 Posted : Saturday, January 7, 2012 8:12:13 AM(UTC)
bobmullen364
Installed new element and oven works fine. Thanks for your help.
ApplianceJunk
#6 Posted : Saturday, January 7, 2012 8:16:19 AM(UTC)
ApplianceJunk
Your welcome,
Maytag Gemini double oven electric (Oven Repair (including Ranges and Cooktops))
by mcelroy69 5/13/2020 10:22:20 AM(UTC)
Maytag Gemini Double Oven Throws Codes After Sensor Replacements (Oven Repair (including Ranges and Cooktops))
by Gfiocca 11/18/2014 9:53:30 AM(UTC)
Maytag Gemini Double oven not working (Oven Repair (including Ranges and Cooktops))
by MTODD101 11/14/2014 1:01:34 PM(UTC)
Maytag Gemini double oven (Oven Repair (including Ranges and Cooktops))
by kdskattum@gmail.com 3/13/2013 6:34:31 PM(UTC)
Maytag Gemini double oven range (Oven Repair (including Ranges and Cooktops))
by Cstewart135 1/18/2013 2:02:46 PM(UTC)
Maytag Gemini Double Oven - Oven lights sporadically (Microwave Repair)
by Marlee 7/4/2011 9:04:46 AM(UTC)
maytag gemini double oven gas range (Oven Repair (including Ranges and Cooktops))
by debo 12/29/2009 6:40:14 PM(UTC)
