My icemaker does nothing but the water dispenser works fine. The optics show two short flashes constantly, with door open or closed. I've had the icemaker out and back in again and could see no mechanical problems.
Originally Posted by: Brian Turnock  ...The optics show two short flashes constantly, with door open or closed... Push and hold the flapper door on the left side emitter module (make sure that the door switch is NOT pushed in) and view the status LED. Post the results. Gene.
Thanks Gene: LED shows two short flashes repeating when left side emitter module flapper is closed (and when open), door switch not pushed. LED goes off when door switch is pushed in closed position. It makes no difference whether icemaker on/off switch is in "on" or "off" position.
Brian, If there is no dirt or frost on optics lenses then the optics boards have to be replaced. - The part number for the kit of optics boards is AP3137510Here are the break down diagrams for the Kitchen Aid refrigerator Model KSRP25FNSS00Gene.
Thanks again, Gene. No frost or dirt; I will replace optics boards and let you know how it goes.
Gene, I replaced the optics boards and WE HAVE ICE! A big "thank-you" to you. Brian
Brian,
You are welcome. I'm glad you were able to fix it.
