ryap7az
#1 Posted : Wednesday, January 4, 2012 1:14:01 PM(UTC)
ryap7az
Lock On light remains illuminated. Following the guidelines in the repair portion of the dishwasher manual, press and hold Heated Dry button for 4 seconds is supposed to unlock the Lock On function. This procedure does not work and I cannot gain any function to the dishwasher Control Panel.
#2 Posted : Wednesday, January 4, 2012 3:23:38 PM(UTC)
Very likely the problem is a bad Heated Dry button on the key panel but there is a small chance for the control board to be bad as well. The key panel is a part of the console.
I would replace the console first. If you need the correct part number, post the color of the console.
ryap7az
#3 Posted : Thursday, January 5, 2012 5:35:45 AM(UTC)
ryap7az
I need the part number for the key pad console, white.
#4 Posted : Thursday, January 5, 2012 11:34:01 AM(UTC)
The white console Part number: AP3885274
Guest (4)
