cerriel
#1 Posted : Friday, February 20, 2009 4:24:09 AM(UTC)
cerriel
Duet dryer (gas): when start button is pressed it trips the breaker. If gas line is disconnected it runs fine. Any suggestions?
#2 Posted : Friday, February 20, 2009 3:33:09 PM(UTC)
There is an electrical short somewhere. You have to take the dryer apart and check all wires and electrical parts. The Service manual might help.
In order you will need a part just type "Duet" in the Search box.
Gas dryer trips breaker (Dryer Repair)
by lightninskyhop 6/26/2012 6:26:10 PM(UTC)
gas dryer trips breaker when rying to heat (Dryer Repair)
by garrywith2rz 9/30/2009 12:41:02 PM(UTC)
