Rocguy
#1 Posted : Saturday, December 31, 2011 9:45:06 AM(UTC)
Rocguy
110 volt gas dryer. Ok, I see alot of posts with this problem. I have cleaned the filter and exhaust duct. I can see the exhaust coming out of the vent on the outside of the house since its around 40 degrees here.
Here is what I see happening. I turn the dryer on, shortly after I can see the glow in the little access door on the bottom right of the dryer. Then the burner starts up. It runs from 1-3 minutes then, shuts off. A few minutes later, this cycle repeats. I've read that coils on the gas valve are a common problem. Would it cycle like a described if those were bad or, would the burner only come on once at the beginning and that's it? My thought is that perhaps the thermostat is shutting it down, then it cools a minute and starts back up? Rinse and repeat so to speak?
I'm going to look into checking the parts with my multimeter but, I wanted to post first to give you time to answer in case I'm on the wrong path. This dryer looks new but is pretty old. Will I be able to find parts for it?
Rocguy
#2 Posted : Saturday, December 31, 2011 5:56:46 PM(UTC)
Rocguy
OK, I took my meter and did some measuring. The thermostats, there is one in the blower case and, one on the top of the burner cage. Both were at 00.3 ohms.
The igniter was 135.8 you can see that in the pictures in my link.
The coils on the gas valve were as follows. Meter set on the 2k ohm setting
2 prong 1.213 ohms
3 prong 1.346 from pin 1(farthest left) to pin2..... pin 1 to pin 3 is .545ohms...... pin 2 to pin 3 is 1.892 ohms
Also before I took it apart a loud rumbling began. After taking the front off, I could see it was in the blower cage. It's like the cage is a bit loose. I can pull it forward probably 1/16 to 1/8 of an inch.
I would appreciate any and all advice and help. Here are some pictures of the inside of my dryer.
Login to a private Photobucket.com album
Rocguy
#3 Posted : Sunday, January 1, 2012 12:59:43 PM(UTC)
Rocguy
I just read a post where a senior member told someone it's usually the high limit thermostat. He said you have to check it by waiting for the heat to kick off and quickly unplug the dryer, pull one wire off of it and, ohm it. Is this the way I have to do it instead of just checking it while the dryer has been off for awhile?
Rocguy
#4 Posted : Monday, January 2, 2012 7:35:01 PM(UTC)
Rocguy
Anyone with any ideas?
ApplianceJunk
#5 Posted : Monday, January 2, 2012 8:29:44 PM(UTC)
ApplianceJunk
Check the blower fan to make sure it's not stripped out in the center.
These fan strip out easy and then don't move the air like they should.
Rocguy
#6 Posted : Tuesday, January 3, 2012 8:00:25 AM(UTC)
Rocguy
Thanks ApplianceJunk, the fan is loose as I described above. Do you think this may be the problem with the burner staying lit as well or, do you think I have two separate problems? I ask because the best I can tell it still seems to spin pretty good it's just become a a little noisy.
EDIT: I took it apart. The wheel is pretty well stripped. One side is supposed to be flat as it slides onto the motor shaft. That flat part is rounded out. Definitely needs replaced. I guess I'll find out if that's the only problem or not.
Rocguy
#7 Posted : Thursday, January 12, 2012 5:33:25 PM(UTC)
Rocguy
Okay, I have replaced the stripped blower wheel but, I still have the problem of the burner not staying lit. I have gale force air coming out the back so I can eliminate air flow. I know for certain the 2 prong gas coil is good because I used it in another dryer that was broke down. It fixed that dryer up so I can use that old one as a temp til I get mine fixed. I guess I will put two new coils in next.
I gave the multimeter readings of things and, symptoms in the first two posts of this thread.
Any advice?
Rocguy
#8 Posted : Sunday, January 22, 2012 9:21:39 AM(UTC)
Rocguy
I replaced the coils on the gas valve and this dryer is now working great again. Thanks for all replies.
ApplianceJunk
#9 Posted : Sunday, January 22, 2012 9:42:12 AM(UTC)
ApplianceJunk
Good job, thanks for the update.
