Rank:: Member
dishwasher blows fuze in upper control panel I replaced the fuze and it ran for a while but would not go through the cycles. It then blew the fuze again. Any help would be appreciated.
Hi Dale The first thing I would check is the right part number for the thermal fuse you used. There are two different thermal fuses used for the dishwashers with a stainless still tubs and a plastic tubs. - The part number for the fuse (110 degrees by C) with a stainless still tub 675796 - The part number for the fuse (98 degrees by C) with a plastic tub 675813What kind of tub has your dishwasher? Gene.
Also when you replace that Fuse you have use those 2 extra wires that come with it. also use the sheild too.
Rank:: Member
When I replaced the fuze I did not use the extra wires because I did not see the need for them since the connections hooked up to the new fuze. I wonder if you can explain to me why the extra wires would be necessary and what the fuzes fuction is designed for.
Dale Westrick
that is whirlpool design to fix the fuse blowing problem. most likly to soak up any extra heat load on the fuse. also when you order the fuse kit. it says to make sure you use and wires.
