Bubbafet
#1 Posted : Tuesday, December 27, 2011 11:51:32 AM(UTC)
Bubbafet
HELP! I need to know how to remove the Retainer from the agitator/cam-drive. What tool do I use? How do I do it? The normal bolt using 7/16 drive is on different models. The cam drive is right below the cap and connected to the lower agitator by a two way bolt. Do I need a special tool to remove the cam or is it something simple? PLEASE HELP!
#2 Posted : Tuesday, December 27, 2011 12:59:03 PM(UTC)
You have to use a 1/2" socket wrench extension to remove the retainer.
- The agitator cam reapir kit Part number: AP3094544
Bubbafet
#3 Posted : Tuesday, December 27, 2011 1:10:34 PM(UTC)
Bubbafet
You are the best Gene! It is that simple; now I just have to find a 1/2" extension to use. I thought that would do it but I was not sure...wanted confirmation before I broke something. I am also perplexed that I could not find this particular video. I have looking at videos for two hours! UGH! But you made it happen! Thanks Gene!!! Again, now I have to see if I have and extention.
#4 Posted : Tuesday, December 27, 2011 1:14:38 PM(UTC)
USCgEEk
#5 Posted : Wednesday, March 6, 2013 5:11:09 PM(UTC)
USCgEEk
hello gene...
i am having problems removing the retainer...with the socket extension inserted, the retainer spins freely in both directions even while holding the lower agitator...any ideas?? :cool:
#6 Posted : Thursday, March 7, 2013 12:23:47 PM(UTC)
Hello,
This retainer made of plastic. Probably the thread is broken. I would try to drill it out.
USCgEEk
#7 Posted : Saturday, March 9, 2013 9:33:48 PM(UTC)
USCgEEk
follow up...
i was able to unscrew the retainer by lifting & holding the top agitator...the retainer was re-installed the same way... :cool:
#8 Posted : Monday, March 11, 2013 12:45:12 PM(UTC)
Were you able to fix the original problem?
