cjrlauve
#1 Posted : Wednesday, February 18, 2009 8:50:09 AM(UTC)
cjrlauve
I spilled water on the interior glass of my oven door and it cracked. A few small pieces of the glass have come out into the oven. Two questions:
1-- Is it necessary to replace it? Can I safely continue to use it with the broken glass? (I have been using it for many months now without any noticable problems.)
2-- I am having a difficult time finding the replacement part. Do I need to plan to replace anything else in this repair? Should I just order the glass?
Thanks for any help.
--John
#2 Posted : Wednesday, February 18, 2009 9:36:21 AM(UTC)
Model JBP26WB5WW
Yes
No
See above link Item 32 in the "Door" section.
Does not look like you will need anything else
Looks like it comes as a window pack same as a dual pane house window
cjrlauve
#3 Posted : Wednesday, February 18, 2009 10:03:05 AM(UTC)
cjrlauve
Thanks. You said item #32 in the door section. I don't see an item 32. I see part 338 that looks like the interior door window to me. Is that the right part?
Also, how to I get the door off the oven for the repair?
Thanks for the help.
-John
#4 Posted : Wednesday, February 18, 2009 1:16:23 PM(UTC)
Yes, that is it. I do not know where I came up with 32.
Here is how to get the door off
http://products.geapplia...&Name=49-80221-1.pdf
Page 42
I think!!!
cjrlauve
#5 Posted : Thursday, February 19, 2009 5:20:23 AM(UTC)
cjrlauve
You're definitely good. I'm impressed. Thanks for all the help. I wish everyone had good customer service like you folks. I'll place my order today.
cjrlauve
#6 Posted : Tuesday, February 24, 2009 12:16:11 PM(UTC)
cjrlauve
Got the replacement glass from AppliancePros. Great! I got the door off the oven. The only way I see to get into the door to replace the glass seems to be by removing the star-screws from the inside panel of the door. True? I need a special screwdriver? Thanks for any help!
#7 Posted : Tuesday, February 24, 2009 12:58:06 PM(UTC)
As far as I know Yes
Yes They are Torx Available at hardware, auto and tool supply stores.
cjrlauve
#8 Posted : Wednesday, February 25, 2009 9:44:20 AM(UTC)
cjrlauve
Thanks again for all your help. Picked up a Torx set from the hardware store (luckily it came with some small sockets too, which it turned out I needed). Took the door off and removed all the screws from the inside panel and the bolts from the bottom and took the door apart. The glass went in without a hitch! Now with the glass looking good, the inside of the oven looks a mess. Ugh. Now I've got to clean that! :)
Thanks for the help!
Guest (6)
