glenross
#1 Posted : Tuesday, February 17, 2009 6:38:47 PM(UTC)
glenross
I just noticed a bit of water emenating from under my chest freezer. there is nothing else around that area to explain the water. so far the freezer appears normal ,with no loss of cooling and the compressor does not appear to be running all the time , but I would like to prepare myself to preserve all the contents if it becomes necessary..would these symptoms indicate that a condenser coil has a leak?
#2 Posted : Wednesday, February 18, 2009 2:05:43 AM(UTC)
A brand and a complete model number would help.
21C just brings up Air Conditioners.
Here is some help on finding it
Model Number Locator
Also is the unit frost free.
glenross
#3 Posted : Wednesday, February 18, 2009 3:43:47 AM(UTC)
glenross
this freezer is 49 years old . made by woods in canada , it is not frost free. is 22 cubic ft capacity. I did not attempt provide that because the question , i felt was pretty general to a refrigeration problem. what i expect is that the freon is leaking slowly , causing condensation in the insulation that is dripping out on to the floor.
do you think i am right? Thankyou for your response.
Don
#4 Posted : Wednesday, February 18, 2009 4:35:56 AM(UTC)
I doubt it is a freon leak.
By now you would have a low freon situation and the unit would run continuously.
More likely either the compressor is getting close to the end of its life or an orifice in the sealed system is clogging up.
See the below link re: Frosted up suction line
Another thing to check is the liner perhaps it has a crack.
Defrosting it may help
Bottom Freezer Leaking Water (Refrigerator & Freezer Repair)
by fscel 2/13/2024 11:22:53 AM(UTC)
Freezer leaking water in dispenser tray (Refrigerator & Freezer Repair)
by Robak 7/3/2014 11:11:02 AM(UTC)
Freezer leaking water from ceiling vent (Refrigerator & Freezer Repair)
by dhog 4/24/2013 7:31:52 PM(UTC)
Freezer leaking water in refrig (Refrigerator & Freezer Repair)
by Waza 11/28/2011 7:01:41 PM(UTC)
Maytag Freezer Leaking Water From Ice Maker (Refrigerator & Freezer Repair)
by PASADENASBUICK 10/8/2010 6:59:32 AM(UTC)
Freezer leaking water into fridge? (Refrigerator & Freezer Repair)
by johnfrancis 11/24/2008 9:04:47 AM(UTC)
Chest freezer leaking water (Refrigerator & Freezer Repair)
by larena 7/28/2007 8:42:17 AM(UTC)
