cav57
#1 Posted : Sunday, December 25, 2011 2:43:59 PM(UTC)
cav57
Dryer will not dry any clothes; blower belt (8544742) is in tact but did notice some pieces with bulkhead and drum removed. Previously had to re-install < 6 month new pulley came loose.
Thermal fuse (3390719) and radiant sensor (338906) passed continuity test. Igniter (686590) looked good and had a 85.6 ohm reading (50-400 ohm norm).
This is a propane conversion unit; I removed orifice and it was not clogged.
What else can I check?
ApplianceJunk
#2 Posted : Sunday, December 25, 2011 3:12:44 PM(UTC)
ApplianceJunk
Can you see the ignitor come on?
cav57
#3 Posted : Sunday, December 25, 2011 7:01:51 PM(UTC)
cav57
No I can not see anything thru the small hole in the front panel. Nor do I hear the flame. I have to install the bulkhead to maintain the flow but could remove it temporarily with door switch connected to see if I can see any initial glow of the igniter. I guess it should be visible. I know however if it has no flow then it will not ignite. (belt came off once and would not generate heat)
Turned out to be thermal cutoff 8573713 - open circuit
Maytag gas dryer - no heat (Dryer Repair)
by sdyak 5/30/2011 1:47:59 PM(UTC)
Maytag Gas Dryer - No Heat - Intermittent (Dryer Repair)
by backbeat 2/2/2010 7:19:48 AM(UTC)
Maytag Gas Dryer - No heat Issue... (Dryer Repair)
by dsmstorm 11/25/2009 4:04:03 PM(UTC)
