Gene,
I got it working - frozen water in door.
Thanks for your help.
Kevin
You are welcome Kevin.
I'm glad you were able to fix it.
Gene, I was cleaning underneath the refrigerator and bumped the union connector. Now it wont stop leaking....I have tried pushing the connector with the copper tubing together, turning clockwise, counter clockwise and nothing will get it to stop short of closing the valve switch to the right of the connector. I barely touched this part, odd that it would cause this much trouble. Any ideas how to get the leak to stop so I can turn the valve back on? Thanks J Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Kevin, Disconnect the water tube at the union-connector (#553 on the diagram). Place a container under the right side of the tubing to catch any water. Keep the freezer door closed or tape in the door switches and depress the water dispenser lever. If there is water coming out with a good pressure, the water line inside the freezer door is frozen up. If there is no water, then there is something wrong with the water supply to the refrigerator or the water inlet valve is bad. Gene.
What is the complete model number of the refrigerator?
HI Gene, the model number is ZISB48DCA , GE Monogram built-in. thanks J
Using a sharp knife, cut the plastic tubes about 2" of the union connector. Replace the union connector by plugging in the plastic tubes. - The union connector Part number: AP3663284
HI Gene, Here is a picture of my part. The red arrow indicates where the water leak comes from when I turn the blue valve to on. From your response I am unclear as to where I should cut. Maybe I gave you the wrong part name? ![UserPostedImage](http://dl.dropbox.com/u/6097576/1.jpg)
The part on the picture does not belong to the refrigerator. Most likely this is a part of a plumbing. Your refrigerator is build in the cabinet and the main water shut off valve probably is on the wall behind the refrigerator. This part looks like an additional shut off valve.
I believe this is not a DIY job. You have to hire a plumber.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You are welcome Dave. I'm glad it's up and running.
Gene. Gene, I have another issue with the refrigerator/freezer which I just posted. Ice cream is soft in freezer, refrigerator is cool, but not cold. Still makes ice... Repairmen charged the system which worked for about 10 days. What else might be the issue? Dave
