kbrutschy
#1 Posted : Wednesday, December 21, 2011 11:03:46 AM(UTC)
kbrutschy
Approximately 8 year old washer developed vibration, rubbed against outer rear tub, broke it. Just replaced rear tub/bearing, works fine during wash cycle but starts shaking violently during spin cycle. Could this be anything other than broken spider arm requiring drum replacement? Machine is level.
sidfink43
#2 Posted : Thursday, December 22, 2011 4:59:54 PM(UTC)
sidfink43
If it is not the support struts then the broken spider is the likely problem. This happens frequently when the rear bearing goes out.
