2 Pages12>
BOB MIA
#1 Posted : Sunday, February 15, 2009 4:52:31 PM(UTC)
BOB MIA
Dropped cup and broke glass on my cooktop(freestanding unit). Have ordered new glass. How is glass released from cooktop? Is a repair manual available for this item?
#2 Posted : Monday, February 16, 2009 12:56:54 PM(UTC)
Bob,
You have to remove the whole cooktop from the counter. Remove all knobs. Remove the screws around the burner box and lift the glass panel up.
Here are the break down diagrams and the parts list for the GE cooktop Model JP340BA2BB
BOB MIA
#3 Posted : Wednesday, February 18, 2009 9:56:18 AM(UTC)
BOB MIA
Gene:
Thanks for the info on the cooktop replacement. You made it a snap and saved me $250. Thanks. :)
#4 Posted : Wednesday, February 18, 2009 3:18:48 PM(UTC)
You are welcome. I'm glad you were able to fix it.
liana
#5 Posted : Wednesday, February 18, 2009 3:23:21 PM(UTC)
liana
Hello Gene would you happen to know how to replace or instructions on replacing a Dacor glass cermaic cooktop, part # 12418b?
#6 Posted : Wednesday, February 18, 2009 3:58:06 PM(UTC)
Liana,
What is the complete model number of the unit?
liana
#7 Posted : Wednesday, February 18, 2009 3:59:50 PM(UTC)
liana
Thank you so much for getting back to me the complete model is ETT365B AND PART NUMBER IS 12418B
#8 Posted : Wednesday, February 18, 2009 4:19:06 PM(UTC)
Liana,
As far as I can see on the diagram the procedure is pretty similar to the GE cooktop above. The whole unit has to be removed from the counter.
liana
#9 Posted : Wednesday, February 18, 2009 4:24:02 PM(UTC)
liana
Any special instructions on how to remove it, and install the new one,, any thing would help.. you had a few step by step instructions for the Ge one should I use the same procedure?
"remove the whole cooktop from the counter. Remove all knobs. Remove the screws around the burner box and lift the glass panel up.??
Please advise anything would help there for I am clueless on how to replace it?
#10 Posted : Wednesday, February 18, 2009 4:42:49 PM(UTC)
Originally Posted by: liana Go to Quoted Post
...you had a few step by step instructions for the GE one should I use the same procedure?...
..."remove the whole cooktop from the counter. Remove all knobs. Remove the screws around the burner box and lift the glass panel up."...
Liana,
This job is a little bit more difficult because this cooktop is more complicated than GE. It does not have knobs because it operates by the touch pads. You can use most of these instructions, but I can not give you any advise on how to remove the cooktop from the counter because I do not know how it was installed.
If you feel not very comfortable with this job it might be better to buy the part and to hire a pro to do it for you, especially because the part is very expensive.
2 Pages12>
