anniesmomrocks
#1 Posted : Friday, February 13, 2009 3:52:38 PM(UTC)
anniesmomrocks
I am wondering if you would be kind enough to tell me how to remove the front panel so that I can replace the broken belt?
The instructions say: "raise dryer top and remove front panel"
How is this done?
Thank you in advance,
anniesmomrocks
jimreaper
#2 Posted : Friday, February 13, 2009 7:06:05 PM(UTC)
jimreaper
Always unplug an appliance before working on it. The top can be a little tricky to "raise". Try using something like a screwdriver to pry the top up a little in from the front corners. Be careful not to chip the finish. When the lid is up you'll see the type of clips that are holding the front on. The drum rotates on the lip on the front panel. So when you remove the front the drum will come loose. Be careful. The belt will go around the drum and will loop around the motor pulleys. Hope this helped.
anniesmomrocks
#3 Posted : Monday, February 16, 2009 9:52:55 AM(UTC)
anniesmomrocks
Dear Jimreaper,
Thank you so much:) I removed the front panel and located the drum, motor, pullys, etc. However, since the belt was already broken, I did not see how the pully idler arm was positioned. We did a great job disassembling the dryer, now all I need is advice to put it back together :)
HELP !!!
anniesmomrocks
jimreaper
#4 Posted : Monday, February 16, 2009 11:16:03 AM(UTC)
jimreaper
I got a response from somebody saying that I gave you the wrong instructions. That's how I recall doing it. Anyway, be sure that you put the belt on the drum first and reassemble the drum and cabinet assembly. From what I remember last time I did one of these there should be a bottom access panel in the front. With everything back together the belt will be hanging down. It will need to be looped around the drive pulley on the motor. There is an idler pulley that should be spring-loaded. It will probably need to be moved to the side so that when it is released it will put tension on the belt. I'm writing this from memory. It's been a few years since I've done one of these. Hope this helps.
anniesmomrocks
#5 Posted : Monday, February 16, 2009 12:00:34 PM(UTC)
anniesmomrocks
Dear jimreaper,
You rock !!! The dryer is reassembled and it works !!! It's funny, when I sat down to write to you, there were the directions that came with the part, sitting right next to the computer...just like the ones you gave me...
Thank you so much for your great advice :)))
anniesmomrocks
jimreaper
#6 Posted : Monday, February 16, 2009 12:12:13 PM(UTC)
jimreaper
Glad to be able to help.
Help!!! Need Kenmore Dryer Repair Manual!!! (Dryer Repair)
by jonzo 10/1/2010 5:36:51 AM(UTC)
Kenmore Dryer Repair (Dryer Repair)
by rvanetten 11/7/2007 6:24:37 AM(UTC)
