dh12
#1 Posted : Saturday, December 17, 2011 6:19:59 PM(UTC)
dh12
kenmore washer gives f2 code replaced pump and cleaned drain lines still get f2 code
ApplianceJunk
#2 Posted : Saturday, December 17, 2011 6:31:20 PM(UTC)
ApplianceJunk
You probably know all this already, but we have to start someplace. ;)
F2=Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Does it seem to get all the water pumped out in time or does it pump out slow?
ApplianceJunk
#3 Posted : Saturday, December 17, 2011 6:32:07 PM(UTC)
ApplianceJunk
I was also thinking this was a duet, but see you did not post a model number.
What is the model number?
dh12
#4 Posted : Saturday, December 17, 2011 7:18:29 PM(UTC)
dh12
already replaced pump water does seam to drain well but pump continues to run then f2 appears model number 11045872403
Guest (5)
problems with washer (Washer Repair)
by zerimar242 10/23/2011 8:27:31 AM(UTC)
Problems with washer (Washer Repair)
by goodangel200 3/20/2008 7:01:13 AM(UTC)
