2 Pages12>
hotpilot
#1 Posted : Saturday, February 14, 2009 1:28:03 PM(UTC)
hotpilot
While in spin cycle, the water flows constantly instead of intermittently. When this is happening, I unplug the machine and the water stops. Any ideas?
#2 Posted : Sunday, February 15, 2009 3:16:30 AM(UTC)
Seems like your timer failed and is not sending voltage to the timer motor.
If so, you might try some non-residue cleaning spray to clean the timer contacts. Just turn the timer while doing this. If a plastic timer, just spray in by the opening near the connector.
hotpilot
#3 Posted : Monday, February 16, 2009 6:22:54 AM(UTC)
hotpilot
Thank you for your help, what would you call a "non-residue cleaning spray" WD-40?
#4 Posted : Monday, February 16, 2009 10:10:56 AM(UTC)
NO. WD-40 leaves a coating of thin oil that will eventually burn the contacts.This is a cleaning spray available for electonics and sold at Lowes.
hotpilot
#5 Posted : Tuesday, February 17, 2009 8:18:07 AM(UTC)
hotpilot
Can you explain more clearly where I am supposed to spray the contact cleaner? Also, I discovered that after the washer enters the rinse/spin cycle, the dial stops moving.
#6 Posted : Tuesday, February 17, 2009 10:27:33 AM(UTC)
Look for any opening in the timer body, preferably near the connector. Helps to have a spray nozzle also.
hotpilot
#7 Posted : Thursday, March 5, 2009 7:33:06 AM(UTC)
hotpilot
Replaced the timer still have the same problem. The timer will not advance. It stops when it gets to the:
SPIN/SPRAY/RINSING
12 MINUTES
This is where the dial indicator is
#8 Posted : Thursday, March 5, 2009 1:40:54 PM(UTC)
Are you saying the timer stops in rinse and never advances.
hotpilot
#9 Posted : Thursday, March 5, 2009 6:57:56 PM(UTC)
hotpilot
Yes. It stops when the water enters the cycle. The water is suppposed to spray off and on, but it only sprays continuously, and the dial does not move.
#10 Posted : Friday, March 6, 2009 12:19:41 AM(UTC)
Sounds like a bad timer. If you have a meter, the timer motor is supposed to get voltage during spin and turn the timer dial.
2 Pages12>
