sgonz1006
#1 Posted : Friday, February 13, 2009 4:09:24 PM(UTC)
sgonz1006
My side by side refrigerator does not get cold and freezer not working properly, also to warm. I checked the thermostat for continuity. I even put one end of the bulb in Ice water and it did operate at different temperatures, it tested good. I replaced the overload and cleaned the coils underneath, they were very dirty. The compressor seems to go on, I put my hand on it and I feel it running yet it does not seem as loud as it was. It seems very quiet. The coils underneath do not get warm either. I wanted to know how to check the DEFROST TIMER BOARD. I am not sure that's it but before I buy that part I would like to be sure. I just spent $50.00 on an overload I did not need. Any help is greatly appreciated. Thank to all.
#2 Posted : Saturday, February 14, 2009 4:28:38 AM(UTC)
Model ED22DCXBB00
Remove the covers in the freezer so you can see the evaporator coils.
If they are heavily iced up you have a defrost problem.
If they are just covered with frost unit probably working. Is the evaporator/freezer fan running?
If they are just frosted/iced up in one area (usually near the input side of the coil), you probably have a low freon/leak problem.
Here is a good link
http://www.applianceaid.com/refrigerator.html
Check out #20
