edvig
#1 Posted : Friday, February 13, 2009 6:34:02 PM(UTC)
edvig
The ice maker is overflowing the ice cube mold with water.
I forced the water cycle using t&h and water valve ran for 22 seconds resulting in the overflow. Would like to know if I need a new power module or water valve?? I also tried adjusting the adjustment screw on right side of power module to no avail.
Other than that Ice maker works fine, ejects ice and so on.
kayakcrzy
#2 Posted : Saturday, February 14, 2009 1:00:08 PM(UTC)
kayakcrzy
i would replace the motor module. most of the times it gets stuck in the fill cycle, and overflows. tom [url=]applianceeducator.com - parts[/url]
