5 Pages<12345>
frank the tank
#21 Posted : Wednesday, December 14, 2011 8:43:25 AM(UTC)
frank the tank
Gene, I tested the yellow wires going from upper limit and start with the neutral. The digital reading is .8 from upper limit and .9 from start wire. According to schematic it says this test should read 3-5 ohms. What does this mean.
frank the tank
#22 Posted : Wednesday, December 14, 2011 9:51:09 AM(UTC)
frank the tank
Is it possible the switch is bad eventhough continuity yeast checks out? I mean I took the top off to watch it.cycle and It's hitting the. Upper limit metal tab and not shopping. I've checked and it us fully engaged.
#23 Posted : Wednesday, December 14, 2011 2:46:04 PM(UTC)
You have been a member since:: 7/19/2007(UTC)
Originally Posted by: frank the tank Go to Quoted Post
#14 was rechecked with wires off. I get a reading then when button is depressed reading is no more...
Frank,
This switch is normally open what means the correct resistance reading while the switch button is not depressed should be infinite. The correct reading with the button depressed should be closed to 0 Ohms.
Looks like this switch is the culprit.
frank the tank
#24 Posted : Wednesday, December 14, 2011 3:18:20 PM(UTC)
frank the tank
You must have misunderstood my statement. I get infinite then when i press the button it goes to 0. What i believe.. and I am not holding my breath on this one.... is that there is a short in one of the wires connected to the start switch. I get a .9 reading on the wire whn according to the manual should be 3-5. It makes sense in that the Compactor did not start by itself all the time as it is now. I'm believing the wire was shouting occasionally. When i replaced the centrifugal switch I must have pulled on the wire and made the short worse and thus causing the constant start when the drawer is pushed in. I checked and the button isn't even being activated yet the cycle starts. Will ck tomorrow and update everyone.
#25 Posted : Wednesday, December 14, 2011 4:30:39 PM(UTC)
According to the Tech sheet (attached to the reply) the test you described as
Quote:
... I tested the yellow wires going from upper limit and start with the neutral. The digital reading is .8 from upper limit and .9 from start wire. According to schematic it says this test should read 3-5 ohms...
is testing the motor run winding. Per this result the motor run winding is shorted and the motor should not run, but per your previous post it does run.
All these results are very confusing.
File Attachment(s):
KUCS03FTSS0 Tech Sheet - 9871923.pdf (203kb) downloaded 19 time(s).
frank the tank
#26 Posted : Wednesday, December 14, 2011 5:02:21 PM(UTC)
frank the tank
Your telling me... I had an ekectrician friend come over today and he was at a loss too. Is it possible the door safety switch can cause the unit to start cycling if it was defective? I believe the cycle starts as soon as that is depressed by the drawer. I noticed this was occurring when the drawer wasn't closed far enough to hit the start button. Just curious.
#27 Posted : Wednesday, December 14, 2011 5:33:05 PM(UTC)
...I believe the cycle starts as soon as that is depressed by the drawer...
No. That switch has to be depressed by the pedal by moving the pedal up.
Would it start by itself (the drawer is in) if the "On-Off" switch on the control panel is in "Off" position?
frank the tank
#28 Posted : Wednesday, December 14, 2011 5:45:09 PM(UTC)
frank the tank
Gene when i push the drawer in but not closed or even itching the start button it will operate. I was thinking of the switch inside that gets depressed when the drawer is pushed in. The unit will not operate if It's turned off.. so I got that going for me.
frank the tank
#29 Posted : Thursday, December 15, 2011 9:11:39 AM(UTC)
frank the tank
Today I took it apart for the umpteenth time.......
I checked that drawer safety switch. I pressed it in and the ram started going up and down near the top. There was blue flashing inside the switch and after a few it stopped and I smelled the electric wire burn smell. I rechecked the switch and get no reading. When the switch is activated I get a reading. ????????????????
#30 Posted : Thursday, December 15, 2011 11:45:30 AM(UTC)
Frank,
There are a few switches and it's hard for me to guess which one did you mean. Can you refer to the numbers from the diagrams please?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUCS03FTSS0 TRASH COMPACTOR | AppliancePartsPros.com
5 Pages<12345>
