misterfixall
#1 Posted : Tuesday, December 13, 2011 11:54:13 AM(UTC)
misterfixall
whirlpool duet F/L washer only 3 months old . only used 1 time , new home owner, did not move in till 3 months later , but machine was tested upon delivery, then they moved in a it acted up 1st time , water comes in, door locks , then unlocks , then locks,starts to count down , then a feww monutes later shows f28 and thats it , i did a diagnostic test, showed F28, check connection to mcu +ccu all looks good / pump connections look good. pump is clean, pressure switch is good +hose is clear. any ideas , this has the new style ccu at right front at top, any ideas / thanks
ApplianceJunk
#2 Posted : Tuesday, December 13, 2011 12:11:44 PM(UTC)
ApplianceJunk
Being less then a year old it's under warranty and you should not have to mess with it. Call Whirlpool and get it fixed under warranty.
ApplianceJunk
#3 Posted : Tuesday, December 13, 2011 12:14:13 PM(UTC)
ApplianceJunk
My bad, looks like you are the tech trying to repair it.
Did you unplug all the connection and plug them back in again?
misterfixall
#4 Posted : Tuesday, December 13, 2011 12:47:11 PM(UTC)
misterfixall
yes i unplugged +replugged the connections
