i have a kitchen aid superb model #KGRT607HBL4. the door handle is coming off and is screwed in from the inside. there is no way to access this. it looks like, from the diagram, i have to take the bottom panel off and then go thru layers to get to the handle. the glass in-between the door is dusty and also needs to be cleaned. how do i get to the insides?
To clean the glass you will have to remove the door from the oven and take the door apart layer by layer, there is no other way.
To tighten the door handle you maybe able to remove just that top plastic grill, but be careful of the outside glass panel falling out.
how would i take the panel off? no screws and it doesn't pop off.
